Wall Mount Wireless Access Point
WN370
WN370_productcarousel_hero_image
1 / 4
Port Types
  • 1 x 10/100/1000 Mbps (PoE 802.3af)
  • 1 x 10/100 voice port
  • 4 x 10/100Mbps (data)
  • 1 x 10/100 Mbps (voice passthrough)
The WN370 Wall Mount Access Point is designed specifically for in-room coverage for wired and wireless access for small and medium hotels and education dormitories. The WN370 has a sleek, elegant, and compact design that allows the AP to be deployed in an inconspicuous manner and can be installed quickly by non-technical personnel. The WN370 is powered with PoE with 1Gbps uplink and 4 (100 Mbps) Ethernet data ports, plus additional voice port for connectivity to digital phones. The WN370 is centrally managed by an enterprise class wireless controller with automatic RF and power tuning with guest captive portal and comprehensive wireless security.
WN370
WN370 • Wallmount • Access-Points
Port Types
Features and benefits
Small form factor and inconspicuous appearance
The aesthetically pleasing design of the WN370 allows the access point to blend nicely in the hotel room and school dormitories. WN370 provides wired access directly to the users, where the traditional form factor Access Points are normally installed on the ceiling, away from the access of the users that need wired connectivity. The WN370 is installed with easy attachment to the junction box and appears with a nice decorative appearance.
Fast installation and PoE powered
The WN370 can be installed easily and less than 5 minutes. The WN370 ships with mounting brackets and fits into both US and EU standard electric junction boxes. Only 4 screws are needed to reliably install the WN370 to the wall with low protrusion. The WN370 is powered via Power over Ethernet on the 1 Gbps uplink. Simply connect a Ethernet cable between the WN370 and a PoE enabled switch and the WN370 is up and running. There is no separate power cord needed.
Product Datasheet
Product Specifications
Dimensions(L x W x H): 135.2 x 93.1 x 25.9mm (5.46 x 3.80 x 1.16in)
Weight0.218kg, 0.481lb
PowerPower over Ethernet
MountingWall mounting to Electric Junction Box
CaseSupport US and UN electric junction boxes
Designed to fit in standard US style electrical junction box of NEMA-WD6 and standard EU or china style electrical junction box of BS4662
Interfaces and IndicatorsN/A
Physical InterfacesUplink: 1 x 10/100/1000 Mbps (PoE) + 1 10/100 voice port
Downlink: 4 x 10/100Mbps (data) + 1 10/100 Mbps (voice passthrough)
PoE802.3af Power over Ethernet (PoE)
LEDs3: Power, Status, WLAN
Default ResetN/A
Environmental ConditionsN/A
Operating Temperature32° to 113° F (0° to 45° C)
Storage Temperature-4° to 158° F (-20° to 70° C)
Operating Relative Humidity10% to 90%
Storage Humidity5% to 95%
MTBF@ 25° C > 375,000 hours
@ 50° C >125,000 hours
Typical Power Consumption5.1 Watts
RF CharacteristicsN/A
StandardsIEEE 802.11n 2.0 specification
IEEE 802.11g
IEEE 802.11b
Frequency Band2.4GHz
802.11n Transmit x Receive2x2
Maximum Theoretical Throughput300 Mbps
Antenna TypeInternal
Antenna Gain3 dbi
Maximum Transmit Power21 dBm @ 802.11b (1Mbps)
21 dBm @ 802.11g (6 Mbps)
21 dBm @ 802.11n (MCS0)
Minimum RX SensitivityUp to -92 dBm
Network ManagementN/A
Deployment options - controller managedWeb UI
CLI
Support for WC7500, WC7600v1, WC7600v2, WC9500
SNMPSNMP v1, v2 with 802.11 standard and proprietary MIBs
FeaturesN/A
Wireless SecurityWEP, WPA, WPA2, 802.1x
Advances Wireless FeaturesIEEE 802.1x Radius (EAP TLS, TTLS, PEAP)
Wireless access control to identify authorized wireless devices
MAC ACL
Rogue AP detection
Heat Map
Guest Access and Captivel Portal
Auto Healing
Auto RF adjustments
Auto AP power adjustments
VLAN
802.11 WMM (Wireless Multimedia mode for QoS)
Multiple BSSIDup to 8
Safety CertificationUL/cUL, CE (EN60950-1)
Countries Certification (minimum set)FCC, IC, CE, EN55022/24, EN301489, EN301489-17, EN30328, EN60950,
C-Tick, A-Tick, SRRC
Optional SupportPMB0351: 5 years OnCall 24x7
PMB0331: 3 years OnCall 24x7
PMB0311: 1 year OnCall 24x7
Product Ordering InformationWN370-10000S
SupportLifetime Next Business Day Hardware Replacement. Click here for coverage, availability and terms and conditions.
ProSUPPORT 24x7 Advanced Technical Support via phone for 90 days (Remote diagnostics performed by our technical experts for prompt resolution of technical issues). ProSUPPORT coverage can be extended by purchasing one, three, or five year contracts.
ProSUPPORT Lifetime 24x7 Advanced Technical Support via chat.
WarrantyThis product is backed by a NETGEAR ProSAFE® Limited Lifetime Hardware Warranty.
Support
Package ContentsWireless-N Access Point
Wall-mount kit
Installation guide
Warranty/support information card
