8-Port Gigabit Ethernet Unmanaged Switch
GS108
1 / 9
GS108
ETHERNET PORT CONFIGURATION
8 Gigabit ports
PLUG-AND-PLAY
FULL PERFORMANCE
Reliable Performance
Superior network performance at non-blocking rate delivers true Gigabit speed with no compromise
High Quality
Durable metal case and long product life
Energy Efficient
SILENT OPERATION
ENERGY EFFICIENT
Designed to optimize power usage lowering its cost to operate
Metal Case
Durable and Rugged
VERSATILE MOUNTING OPTIONS
Supports desktop or wall placement, and includes wall mounting kit in the box
STANDARDS-BASED DESIGN
Ensure interoperability with any standards-based PDs
Weight : | 0.47 kg (1.04 lb) |
Dimensions : | 158 x 102 x 27 mm (6.2 x 4.0 x 1.1 in) |
Product name : | NETGEAR 8-Port Gigabit Ethernet Unmanaged Switch (GS108) |
Speed : | 10/100/1000Mbps Gigibit Ethernet |
Number of Ports : | 8 |
PoE ports : | n/a |
Total PoE Budget : | n/a |
Loop Detection : | n/a |
Short cable power saving : | n/a |
Energy Efficient Ethernet Support (IEEE 802.3az): | Yes |
Jumbo Frame Support : | Up to 9K packet size |
Queue WRR Ratio : | 1:2:4:8 |
MAC Table Size : | 4K |
Packet buffer size : | 192KB |
IEEE 802.1p QoS : | Yes |
Operating Temperature : | 32° to 104°F (0° to 40°C) |
FCC Class : | B |
Energy Efficient Ethernet support : | Yes - Compliant with IEEE802.3az Energy Efficient Ethernet mode |
Jumbo frame support : | 9,216 bytes |
Warranty : | Limited lifetime support** |
Technical Support (online, phone) : | 90 days free from date of purchase |
| | Extended ProSupport Support and Warranty Available |
| | Support |
