32xSFP+ and 8xSFP28 25G Managed Switch
XSM4340FV
1 / 8
- 40 Ports
Port Types
- 32 x 10G SFP+
- 8 x 25G SFP28
PoE Budget
- N/A
- 32 10GBASE-X SFP+ ports with 8 25GBASE-X SFP28 uplinks
- 420W internal power supply
- 1 slot for modular power supply (1+1 redundancy)
- Any APS600Wv3, APS1200Wv2, or APS2000Wv2 can be used
- Virtual Chassis stacking provides non-stop forwarding (NSF) and hitless failover
- Layer 3 feature set includes static, policy-based, and dynamic routing
- NETGEAR IGMP Plus™, AV User Interface, and Engage Controller speed up AV installations
- TAA compliant SKU is available. Contact your sales representative
- 40 Ports
Port Types
- 32 x 10G SFP+
- 8 x 25G SFP28
PoE Budget
- N/A
PRO AV FAMILY COMPARISON
USE CASE
SWITCH STACKING
PoE CAPABLE
PORT SPEEDS
AVB SUPPORT
AV WEB UI / AV TEMPLATES
AV DESIGN
(FRONT LED'S & REAR CABLING)
M4350-XSM4340FV Technical Specifications
| M4350-32F8V (XSM4340FV) | 1 |
| Power cord(s) | 1 |
| Console USB Type-C cable | 1 |
| Rack-mounting standard bracket set | 1 |
| Set of longer brackets for recessed mounting | 1 |
| Rubber footpads for tabletop installation | 4 |
| Installation guide | 1 |
| Width | 440mm |
| Depth | 400mm |
| Height | 43.2mm |
| Weight | 6.95kg (15.32lb) |
| Primary Port Speed | 10 Gigabit |
| Number of Ports | 40 (32 x 10G SFP+, 8 x 25G SFP28) |
| PoE Ports / Budget | N/A |
| IGMP Support | Enhanced (NETGEAR IGMP Plus™) |
| Jumbo Frame Support | Yes, up to 12kb |
| AVB Support | Yes, included |
| Acoustics | Quiet Mode 32.7dB@25ºC |
| Power Consumption | 156.4W/491.1Btu/hr Standby without any port connection: 42.6W/133.76Btu/hr |
| PSU Compatible Models | APS600Wv3 APS1200Wv2 APS2000Wv2 |
NETGEAR Engage Controller | Centralized application to configure all switches across your entire network. Lightweight and portable, you can run it from a USB thumb drive. |
| This product is backed by NETGEAR limited lifetime hardware warranty. |
| Click here for coverage, availability and terms and conditions. |
| NETGEAR Support offers a customizable support experience based on your operational needs: |
| Support coverage in one, three, or five year contracts |
| Pro AV Information | Learn More |
| M4350-32F8V Support | Learn More |
| AV Resource Center | Learn More |
