16x 2.5G PoE++ (530W base, up to 1,130W) incl. 8x Neutrik etherCON and 4xSFP28 25G Managed Switch
MSM4320
1 / 13
Port Types
- 16x 2.5G PoE++ incl. 8x Neutrik etherCON
- 4x 25G SFP28 uplinks
PoE Budget
- 1130W total when the redundant PoE budget remains 530W (1+1)
- Two internal 800W power supplies providing 530W of redundant base PoE budget
- Switch ships with one APM414V interface card with 4x 25G SFP28 ports
- Optional APM414C Interface Card with 4x 10G RJ-45 ports
- Optional APM414SD Interface Card with 2x Neutrik opticalCON QUAD connectors for 4x MMF transceivers
- Optional APM414LD Interface Card with 2x Neutrik opticalCON QUAD connectors for 4x SMF transceivers
- 2x Neutrik powerCON connectors and C14 male power cord adapters for standard IEC 320 C13 cords
- Virtual Chassis stacking provides non-stop forwarding (NSF) and hitless failover
- Layer 3 feature set includes static, policy-based, and dynamic routing
- NETGEAR IGMP Plus™, NETGEAR AV OS™, and NETGEAR Engage™ Controller speed up AV installations
- SMPTE ST 2110 Grandmaster Clock and Boundary Clock for AES67 and ST2059-2 applications
- Multi-color LED on each physical port reflecting the profile color in the NETGEAR AV OS™ and Engage Controller
MSM4320
Port Types
PoE Budget
PRO AV RESOURCES
PRO AV FAMILY COMPARISON
USE CASE
SWITCH STACKING
PoE CAPABLE
PORT SPEEDS
AVB SUPPORT
AV WEB UI / AV TEMPLATES
AV DESIGN
(FRONT LED'S & REAR CABLING)
M4350-16M4V (MSM4320) Technical Specifications
M4350-16M4V (MSM4320) | 1 |
Power Cord (Standard AC to C13) | 1 |
Neutrik powerCON connectors and C14 male power cord adapters for standard IEC 320 C13 cords | 2 |
Console USB Type-C cable | 1 |
Rack-mounting standard bracket set | 1 |
Set of longer brackets for recessed mounting | 1 |
Rubber footpads for tabletop installation | 4 |
Installation guide | 1 |
Width | 440mm |
Depth | 432mm |
Height | 43.2mm |
Weight | 7.85kg (17.31lb) |
Primary Port Speed | 2.5 Gigabit |
Number of Ports | 20 (16 x 2.5G PoE++ incl. 8x Neutrik etherCON, and 4x 25G SFP28) |
IGMP Support | Enhanced (NETGEAR IGMP Plus™) |
Jumbo Frame Support | Yes, up to 12kb |
AVB Support | Yes, included. |
Acoustics | Quiet Mode 35.6dB@25ºC |
Power Consumption | With max PoE: 1359.8W/4,639.64Btu/hr Without PoE: 109.6W/373.96Btu/hr |
Standby w/o any port connection | 50.6W/170.60Btu/hr |
PSU Compatible Models | Internal only |
Internal PSUs | 2 internal 800W PSUs with PowerCON connectors |
Compatible Interface Cards | APM414SD (2x Neutrik opticalCON QUAD for 4x MMF Transceivers) |
| NETGEAR Engage Controller | Centralized application to configure all switches across your entire network. Lightweight and portable, you can run it from a USB thumb drive. |
Warranty : | This product is backed by NETGEAR limited lifetime hardware warranty. |
| Click here for coverage, availability and terms and conditions. |
Support : | NETGEAR Support offers a customizable support experience based on your operational needs: |
| Support coverage in one, three, or five year contracts |
| Pro AV Information | |
| M4350-16M4V Support | |
| AV Resource Center |
