24-Port Gigabit Ethernet Unmanaged Switch
GS524
- 24 Ports
Port Types
- 24 x 10/100/1000Mbps Ethernet RJ-45 ports
PoE Budget
- n/a
GS524
- 24 Ports
Port Types
PoE Budget
- n/a
RELIABLE PERFORMANCE
Superior network performance at non-blocking rate delivers true gigabit speed with no compromise
ENERGY EFFICIENT
PLUG-AND-PLAY
No software to install. No configuration needed. Zero maintenance required
SILENT OPERATION
VERSATILE MOUNTING OPTIONS
Install your switch on your desktop, mount it to your wall, or add it to a standard 19 inch (44 mm) rack with the hardware provided in the box
METAL CASE
Durable and rugged case for long-lasting performance
Dimensions (WxDxH) | 328 x 169 x 43 mm (12.9 x 6.7 x 1.7in) |
Weight | 1.47kg (3.24lb) |
Speed | 10/100/1000Mbps Gigibit Ethernet |
Number of Ports | 24 |
PoE ports | n/a |
Total PoE Budget | n/a |
Loop Detection | n/a |
Short cable power saving | Yes |
Energy Efficient Ethernet Support (IEEE 802.3az) | Yes |
Jumbo Frame Support | 9KB |
Queue WRR Ratio | 1:2:4:8 |
MAC Table Size | 8K |
Packet buffer size | 512.5KB |
IEEE 802.1p QoS | Yes |
Max Power Consumption | 12W |
Operating Temperature | 0 to 50° C |
MTBF (hours) | 1,016,877 hrs |
FCC Class | A |
Warranty | This product is backed by NETGEAR limited lifetime hardware warranty. |
| Click here for coverage, availability and terms and conditions. |
Support | NETGEAR Support offers a customizable support experience based on your operational needs: |
| Support coverage in one, three, or five year contracts |
