8-Port Gigabit Ethernet Unmanaged Essentials Switch
GS308v3
  • 8 Ports
PoE Budget
  • N/A
NETGEAR Essentials Switches featuring 8 ports of gigabit Ethernet. This switch is plug-and-play with unmanaged ports needing no additional configuration at full non-blocking performance.
Download GS308v3 Datasheet
  • 8 Ports
PoE Budget
  • N/A
Ethernet Port Configuration
8 Gigabit ports
Plug-and-play
Full Performance
Product Datasheet
Carousel Swimlane Image 1 tcm148 112845
Plug-and-Play
No configuration necessary - perfect for small-medium businesses and home office / entertainment
Carousel Swimlane Image 2 tcm148 112846
Smart Energy Savings
Energy efficient Ethernet (IEEE 802.3az) cuts energy consumption during little or no activity on active ports.
Carousel Swimlane Image 3 tcm148 112847
Built to Last
Switches are housed in a solid, compact metal case and rigorously tested for reliability.
Carousel Swimlane Image 4 tcm148 112848
Designed for Zero-Noise Operation
Passively cooled fanless design to protect your business environment
Dimensions
158 x 101 x 29mm (6.2 x 4.0 x 1.1in)
Weight
0.39 kg (0.86 lb)
Model Description
NETGEAR 8-Port Gigabit Ethernet Unmanaged Essentials Switch (GS308v3)
Speed
Gigabit
Number of Ports
8
Connector Type
Metal
Switch Housing
Metal
LEDs
Power, Link/Activity
Short cable power saving
Yes
Yes
Jumbo frame support
9,216 bytes
MAC Table Size
8K
Packet buffer size
192k
DC Power Adapter
12V / 0.5A
Max Power Consumption (Watts)
3.04W
​Acoustic Noise Level @ 25° C (dBA)
0 dBA (Fanless)
​Operating Temperature
0° to 40°C (32° to 104°F)
​MTBF (@ 25° C)
3,711,898 hours
​Electromagnetic compliance (A or B)
Class B
​Form Factor
Desktop or wall-mountable
Warranty
Support
High Resolution Image
Low Resolution Image
Installation Guide
Meural
Free Shipping
Meural
Hassle-Free Returns
