5-Port Gigabit Ethernet Unmanaged Switch
GS105
1 / 8
- 5 Ports
Port Types
- 5 x 10/100/1000Mbps Gigibit Ethernet
PoE Budget
- n/a
GS105
- 5 Ports
Port Types
PoE Budget
- n/a
ETHERNET PORT CONFIGURATION
5 Gigabit ports
PLUG-AND-PLAY
FULL PERFORMANCE
Reliable Performance
Superior network performance at non-blocking rate delivers true Gigabit speed with no compromise
High Quality
Durable metal case and long product life
Energy Efficient
SILENT OPERATION
ENERGY EFFICIENT
Designed to optimize power usage lowering its cost to operate
Metal Case
Durable and Rugged
VERSATILE MOUNTING OPTIONS
Supports desktop or wall placement, and includes wall mounting kit in the box
STANDARDS-BASED DESIGN
Ensure interoperability with any standards-based PDs
Dimensions (WxDxH) @mm : | 94 mm x 100 mm x 27 mm |
Weight (kg) : | 0.261 kg |
Speed : | 10/100/1000Mbps Gigibit Ethernet |
Number of Ports : | 5 |
PoE ports : | n/a |
Total PoE Budget : | n/a |
Loop Detection : | n/a |
Short cable power saving : | n/a |
Energy Efficient Ethernet Support (IEEE 802.3az): | Yes |
Jumbo Frame Support : | Yes |
Queue WRR Ratio : | 1:2:4:8 |
MAC Table Size : | 2K |
Packet buffer size : | 128KB |
IEEE 802.1p QoS : | Yes |
Max Power Consumption : | 2.7W |
Operating Temperature : | 50°C |
MTBF (hours) : | 3,197,945 hours |
FCC Class : | B |
Warranty : | This product is backed by NETGEAR limited lifetime hardware warranty. |
| Click here for coverage, availability and terms and conditions. |
Support : | NETGEAR Support offers a customizable support experience based on your operational needs: |
| Support coverage in one, three, or five year contracts |
