40x10G/Multi-Gig PoE++ (196W base, up to 1,676W) and 4xQSFP28 100G Managed Switch
XSM4344C​​
SWITCHES_XSM4344C-M4350 Hero Image
1 / 8
  • 44 Ports
Port Types
  • 40 x 10G/Multi-Gig PoE++
  • 4 x 100G QSFP28
PoE Budget
  • 40 PoE++ (90W/port)
  • 196W Base
  • up to 1
  • 676W Budget
  • 40 10G/Multi-Gig PoE++ ports with 4 100GBASE-X QSFP28 uplinks
  • 750W internal power supply providing 196W of PoE budget
  • 1 slot for modular power supply (1+1 redundancy and/or EPS share)
  • Any APS600Wv3, APS1200Wv2, or APS2000Wv2 can be used
  • The PoE budget can reach 1,676W, when the redundant PoE budget remains 196W
  • NETGEAR IGMP Plus™, AV User Interface, and Engage Controller speed up AV installations
  • Supports SMPTE ST 2110 for professional broadcast applications
  • TAA compliant SKU is available. Contact your sales representative
Download XSM4344C​​ Datasheet
XSM4344C​​
44 Ports • 40 PoE++ • 100G • up to 1 • 676 W
  • 44 Ports
Port Types
  • 4 x 100G QSFP28
PoE Budget
  • 196W Base
  • up to 1
  • 676W Budget
POWER AND
THROUGHPUT
m4350 simplified desktop
Groundbreaking AV GUI
Multicast in an Instant
Sleek, Quiet Design
Automatic Configuration
Fast, Easy Configuration
for AV Pros
A streamlined interface using certified profiles with settings for any AV or broadcast application assigned to ports with just a few clicks.
m4250-pro-av-dt-5
DESIGNED FOR
AV OVER IP
RIGHT OUT OF
THE BOX
XSM4344C MAXIMIZE PERFORMANCE
MAXIMIZE PERFORMANCE WITH PRO WIFI ACCESS POINTS
Enable powerful, reliable WiFi at your location with Pro WiFi access points, powered by PoE or an external power adapter.
LEARN MORE
PRO AV FAMILY COMPARISON
USE CASE
SWITCH STACKING
PoE CAPABLE
PORT SPEEDS
AVB SUPPORT
AV WEB UI / AV TEMPLATES
AV DESIGN
(FRONT LED'S & REAR CABLING)
M4250 SWITCH SERIES
Access/Edge
No
Yes
1, 2.5, 10Gbps
Yes*
Yes
Yes
M4350 SWITCH SERIES
Core/Access/Edge
Yes
Yes
1, 2.5, 10, 25, 100Gbps
Yes
Yes
No
M4500 SWITCH SERIES
Core/Access/Edge
No (MLAG)
No
1, 10, 25, 100Gbps
No
No
No
M4350-XSM4344C Technical Specifications
M4350-40X4C (XSM4344C)
1
Power cord(s)
1
Console USB Type-C cable
1
Rack-mounting standard bracket set
1
Set of longer brackets for recessed mounting
1
4
Installation guide
1
Width
440mm
Depth
400mm
Height
43.2mm
Weight
7.76kg (17.11lb)
Primary Port Speed
10 Gigabit / Multi-Gig
Number of Ports
44 (40 x 10G/Multi-Gig PoE++, 4 x 100G QSFP28)
PoE Ports / Budget
40 PoE++ (90W/port), 196W Base, up to 1,676W Budget
IGMP Support
Enhanced (NETGEAR IGMP Plus™)
Jumbo Frame Support
Yes, up to 12kb
AVB Support
Yes, included
Acoustics
Quiet Mode 34.1dB@25ºC
Power Consumption
With PoE: 413W/1408.33Btu/hr
Without PoE: 200.4W/629.26Btu/hr
Standby without any port connection: 98.8W/310.23Btu/hr
PSU Compatible Models
APS600Wv3
APS1200Wv2
APS2000Wv2
NETGEAR Engage Controller
Centralized application to configure all switches across your entire network. Lightweight and portable, you can run it from a USB thumb drive.
Pro AV Information
M4350-40X4C Support
AV Resource Center
High Resolution Images
Low Resolution Images
