24xSFP+ and 4xSFP28 25G Managed Switch
XSM4328FV
SWITCHES_XSM4328FV-M4350 Hero Image
1 / 7
  • 28 Ports
Port Types
  • 24 x 10G SFP+
  • 4 x 25G SFP28
PoE Budget
  • N/A
  • 24 10GBASE-X SFP+ ports with 4 25GBASE-X SFP28 uplinks
  • 240W internal power supply
  • 1 slot for modular power supply (1+1 redundancy)
  • Any APS350Wv1, APS600Wv2, APS920Wv1, or APS2000Wv1 can be used
  • NETGEAR IGMP Plus™, AV User Interface, and Engage Controller speed up AV installations
Download XSM4328FV Datasheet
XSM4328FV
28 Ports • 25G
  • 28 Ports
Port Types
  • 24 x 10G SFP+
  • 4 x 25G SFP28
PoE Budget
  • N/A
POWER AND
THROUGHPUT
m4350 simplified desktop
Groundbreaking AV GUI
Multicast in an Instant
Sleek, Quiet Design
Automatic Configuration
Fast, Easy Configuration
for AV Pros
A streamlined interface using certified profiles with settings for any AV or broadcast application assigned to ports with just a few clicks.
m4250-pro-av-dt-5
DESIGNED FOR
AV OVER IP
RIGHT OUT OF
THE BOX
XSM4328FV MAXIMIZE PERFORMANCE
MAXIMIZE PERFORMANCE WITH PRO WIFI ACCESS POINTS
Enable powerful, reliable WiFi at your location with Pro WiFi access points, powered by PoE or an external power adapter.
LEARN MORE
PRO AV FAMILY COMPARISON
USE CASE
SWITCH STACKING
PoE CAPABLE
PORT SPEEDS
AVB SUPPORT
AV WEB UI / AV TEMPLATES
AV DESIGN
(FRONT LED'S & REAR CABLING)
M4250 SWITCH SERIES
Access/Edge
No
Yes
1, 2.5, 10Gbps
Yes*
Yes
Yes
M4350 SWITCH SERIES
Core/Access/Edge
Yes
Yes
1, 2.5, 10, 25, 100Gbps
Yes
Yes
No
M4500 SWITCH SERIES
Core/Access/Edge
No (MLAG)
No
1, 10, 25, 100Gbps
No
No
No
M4350-XSM4328FV Technical Specifications
M4350-24F4V (XSM4328FV)
1
Power cord(s)
1
Console USB Type-C cable
1
Rack-mounting standard bracket set
1
Set of longer brackets for recessed mounting
1
4
Installation guide
1
Width
440mm
Depth
400mm
Height
43.2mm
Weight
6.25kg (13.78lb)
Primary Port Speed
10 Gigabit
Number of Ports
28 (24 x 10G SFP+, 4 x 25G SFP28)
PoE Ports / Budget
N/A
IGMP Support
Enhanced (NETGEAR IGMP Plus™)
Jumbo Frame Support
Yes, up to 12kb
AVB Support
Yes, included
Acoustics
Quiet Mode 34.2dB@25ºC
Power Consumption
119.3W/374.6Btu/hr
Standby without any port connection: 45.2W/141.93Btu/hr
PSU Compatible Models
APS350Wv1
APS600Wv2
APS920Wv1
APS2000Wv1
NETGEAR Engage Controller
Centralized application to configure all switches across your entire network. Lightweight and portable, you can run it from a USB thumb drive.
Pro AV Information
M4350-24F4V Support
AV Resource Center
High Resolution Images
Low Resolution Images
