44x2.5G, 4x10G/Multi-gig PoE++ (194W base, up to 3,314W) and 4xSFP28 25G (MSM4352) Managed Switch
View all accessories
MSM4352
1 / 11
  • 52 Ports
Port Types
  • 44 x 2.5G PoE++
  • 4 x 10G/Multi-Gig PoE++
  • 4 x 25G SFP28
PoE Budget
  • 48 PoE++ (90W/port)
  • 194W base
  • up to 3
  • 314W budget
  • 44 2.5G and 4 10G/Multi-gig PoE++ ports with 4 25GBASE-X SFP28 uplinks
  • 550W internal power supply providing 194W of PoE budget
  • 2 slots for modular power supplies (1+1 redundancy and/or EPS share)
  • Any APS350Wv1, APS600Wv2, APS920Wv1, or APS2000Wv1 can be used
  • The PoE budget can reach 3,314W, the redundant PoE budget can reach 1,794W
  • NETGEAR IGMP Plus™, AV User Interface, and Engage Controller speed up AV installations
  • TAA-compliant SKU is available. Contact your sales representative
Download MSM4352 Datasheet
MSM4352
52 Ports • 48 PoE++ • 25G • up to 3 • 314 W
  • 52 Ports
Port Types
  • 44 x 2.5G PoE++
  • 4 x 25G SFP28
PoE Budget
  • 194W base
  • up to 3
  • 314W budget
POWER AND
THROUGHPUT
m4350 simplified desktop
Groundbreaking AV GUI
Multicast in an Instant
Sleek, Quiet Design
Automatic Configuration
Fast, Easy Configuration
for AV Pros
A streamlined interface using certified profiles with settings for any AV or broadcast application assigned to ports with just a few clicks.
m4250-pro-av-dt-5
DESIGNED FOR
AV OVER IP
RIGHT OUT OF
THE BOX
PRO AV FAMILY COMPARISON
USE CASE
SWITCH STACKING
PoE CAPABLE
PORT SPEEDS
AVB SUPPORT
AV WEB UI / AV TEMPLATES
AV DESIGN
(FRONT LED'S & REAR CABLING)
M4250 SWITCH SERIES
Access/Edge
No
Yes
1, 2.5, 10Gbps
Yes*
Yes
Yes
M4350 SWITCH SERIES
Core/Access/Edge
Yes
Yes
1, 2.5, 10, 25, 100Gbps
Yes
Yes
No
M4500 SWITCH SERIES
Core/Access/Edge
No (MLAG)
No
1, 10, 25, 100Gbps
No
No
No
M4350-MSM4352 Technical Specifications
M4350-44M4X4V (MSM4352)1
Power cord(s)1
Console USB Type-C cable1
Rack-mounting standard bracket set1
Set of longer brackets for recessed mounting1
Rubber footpads for tabletop installation4
Installation guide1
Width440mm
Depth400mm
Height43.2mm
Weight7.34kg (16.18lb)
Primary Port Speed2.5 Gigabit
Number of Ports52 (44 x 2.5G PoE++, 4 x 10G/Multi-Gig PoE++, 4 x 25G SFP28)
PoE Ports / Budget48 PoE++ (90W/port), 194W Base, up to 3,314W Budget
IGMP SupportEnhanced (NETGEAR IGMP Plus™)
Jumbo Frame SupportYes, up to 12kb
AVB SupportYes, included
AcousticsQuiet Mode 34dB@25ºC
Power Consumption
With PoE: 351.5W/1198.62Btu/hr
Without PoE: 133.5W/419.19Btu/hr
Standby without any port connection: 56.5W/177.41Btu/hr
PSU Compatible Models
APS350Wv1
APS600Wv2
APS920Wv1
APS2000Wv1
NETGEAR Engage Controller
Centralized application to configure all switches across your entire network. Lightweight and portable, you can run it from a USB thumb drive.
Warranty :
Support :
High Resolution Images
Low Resolution Images
Visio Stencils
