24x1G PoE+ 480W 2x1G and 4xSFP+ Managed Switch
GSM4230PX
1 / 12
  • 30 Ports
Port Types
  • 24 x 1G PoE+
  • 2 x 1G
  • 4 x SFP+
PoE Budget
  • 24 PoE+ (30W/port)
  • 480W Budget
Switching engineered for 1G AV over IP with rear-facing ports ensuring a clean integration in AV racks. Pre-configured for out of the box functionality!
TAA compliant SKU is available. Contact your sales representative
Download GSM4230PX Datasheet
GSM4230PX
30 Ports • 24 PoE+ • 1G • up to 480 W
  • 30 Ports
Port Types
  • 24 x 1G PoE+
  • 2 x 1G
  • 4 x SFP+
PoE Budget
  • 480W Budget
POWERFUL AV SWITCHES
MADE SIMPLE
m4250-pro-av-dt-2_v2
Groundbreaking AV GUI
Multicast in an Instant
Sleek, Quiet Design
Automatic Configuration
FAST, EASY
CONFIGURATION
FOR AV PROS
m4250-pro-av-dt-4
FOCUS ON THE EVENT
NOT FAN NOISE
m4250-right-out-of-the-box
DESIGNED FOR AV OVER IP
RIGHT OUT OF THE BOX
m4250 pro av 6 tcm148 139921
REFINED DESIGN
PROVIDES MOUNTING FLEXIBILITY
PRO AV FAMILY COMPARISON
USE CASE
SWITCH STACKING
PoE CAPABLE
PORT SPEEDS
AVB SUPPORT
AV WEB UI / AV TEMPLATES
AV DESIGN
(FRONT LED'S & REAR CABLING)
M4250 SWITCH SERIES
Access/Edge
No
Yes
1, 2.5, 10Gbps
Yes*
Yes
Yes
M4350 SWITCH SERIES
Core/Access/Edge
Yes
Yes
1, 2.5, 10, 25, 100Gbps
Yes
Yes
No
M4500 SWITCH SERIES
Core/Access/Edge
No (MLAG)
No
1, 10, 25, 100Gbps
No
No
No
Product Specifications
Dimensions (WxDxH):
440 x 400 x 43.2 mm
Weight:
5.45 kg (12.02lb)
Primary Port Speed:
1 Gigabit
Number of Ports:
30 (24x 1G PoE+, 2x 1G, 4x SFP+)
PoE Ports / Budget:
24 PoE+ (30W/port), 480W Budget
IGMP Support:
Enhanced (NETGEAR IGMP Plus™)
Jumbo Frame Support:
Yes, up to 12kb
AVB Support:
Yes. Electronic license required, activation key sent via email (AVB4230PX-10000S)
Acoustics:
Fanless or 42dB@25ºC
TBD Power Consumption:
With PoE: 614W/2096.2Btu/hr
Without PoE: 46.8W/159.78Btu/hr
Standby without any port connection: 33.9W/115.73Btu/hr
Warranty :
Support :
What's in the Box:
M4250-26G4XF-PoE+ (GSM4230PX)
Power cord(s)
Console USB Type-C and RJ45-DB9 cables
Rack-mounting standard brackets
Longer brackets for recessed mounting
Installation guide
High Resolution Images
Low Resolution Images
Installation GuideUser Manual Product Datasheet
