8x1G PoE+ 125W 2x1G and 2xSFP Managed Switch
GSM4212P
1 / 10
  • 12 Ports
Port Types
  • 10 x 1G
  • 2 x SFP
PoE Budget
  • 8 PoE+ (30W/port)
  • 125W Budget
Designed with input from industry professionals, this switch is engineered for 1G AV over IP. Enjoy rear-facing ports that ensure a clean integration in AV racks, and pre-configuration for out-of-the-box functionality.
Download GSM4212P Datasheet
GSM4212P
12 Ports • 8 PoE+ • 1G • up to 125 W
  • 12 Ports
Port Types
  • 10 x 1G
  • 2 x SFP
PoE Budget
  • 8 PoE+ (30W/port)
  • 125W Budget
POWERFUL AV SWITCHES
MADE SIMPLE
m4250-pro-av-dt-2_v2
Groundbreaking AV GUI
Multicast in an Instant
Sleek, Quiet Design
Automatic Configuration
FAST, EASY
CONFIGURATION
FOR AV PROS
m4250-pro-av-dt-4
FOCUS ON THE EVENT
NOT FAN NOISE
m4250-right-out-of-the-box
DESIGNED FOR AV OVER IP
RIGHT OUT OF THE BOX
m4250 pro av 6 tcm148 139921
REFINED DESIGN
PROVIDES MOUNTING FLEXIBILITY
PRO AV FAMILY COMPARISON
USE CASE
SWITCH STACKING
PoE CAPABLE
PORT SPEEDS
AVB SUPPORT
AV WEB UI / AV TEMPLATES
AV DESIGN
(FRONT LED'S & REAR CABLING)
M4250 SWITCH SERIES
Access/Edge
No
Yes
1, 2.5, 10Gbps
Yes*
Yes
Yes
M4350 SWITCH SERIES
Core/Access/Edge
Yes
Yes
1, 2.5, 10, 25, 100Gbps
Yes
Yes
No
M4500 SWITCH SERIES
Core/Access/Edge
No (MLAG)
No
1, 10, 25, 100Gbps
No
No
No
Product Specifications
Dimensions (WxDxH):
440 x 200 x 43.2mm
Weight:
2.85Kg (6.28lb)
Primary Port Speed:
1 Gigabit
Number of Ports:
12 (10x 1G, 2x SFP)
PoE Ports / Budget:
8 PoE+ (30W/port), 125W Budget
IGMP Support:
Enhanced (NETGEAR IGMP Plus™)
Jumbo Frame Support:
Yes, up to 12kb
Acoustics:
Fanless or 30dB@25ºC
Power Consumption:
With PoE: 163.9W/559.555Btu/hr; Without PoE: 17.32W/59.13Btu/hr; Standby without any port connection: 8.53W/29.121Btu/hr
AVB Support:
Yes. Electronic license required, activation key sent via email (AVB4212P-10000S)
Warranty :
Support :
What's in the Box:
M4250-10G2F-PoE+ (GSM4212P)
Power cord(s)
Console USB Type-C and RJ45-DB9 cables
Rack-mounting standard brackets
Longer brackets for recessed mounting
Installation guide
High Resolution Images
Low Resolution Images
Installation GuideUser Manual Product Datasheet
