5-Port Gigabit Ethernet Easy Smart PoE+ Switch (63W)
GS105EP
- 5 Ports
Port Types
- 5 x 10/100/1000 RJ45 Copper Ports (Auto Uplink)
- 4 x PoE+ 802.3at Ports
- 0 x SFP fiber ports
PoE Budget
- Up to 63W
GS105EP
- 5 Ports
Port Types
PoE Budget
- Up to 63W
EASY POE CONTROLS
Manage PoE prioritization, PoE power limit per port, PoE scheduling and more for advanced control over all PoE-powered devices
GIGABIT ETHERNET
5 ports provide gigabit Ethernet connectivity to your devices
VLANS
FANLESS DESIGN
VERSATILE MOUNTING OPTIONS
Place your switch on your desktop or mount it to your wall with the hardware provided in the box. Silent operation makes this switch perfect for noise-sensitive environments
ENERGY EFFICIENT
Dimensions (W x D x H) : | 158 x 101 x 27 mm (6.22 x 4.00 x 1.06 in) |
Weight : | 0.39kg (0.86 lb) |
Speed : | 1G |
Number of Ports : | 5 |
Number of PoE+ Ports : | 4 |
PoE Power per Port : | Up to 30 |
PoE Budget : | Up to 63W |
Energy Efficient Ethernet Support (IEEE 802.3az) : | Yes |
Jumbo Frame Support : | 9,216 bytes |
MAC Table Size : | 2K |
Packet buffer size : | 1.5 MB |
IEEE 802.1p QoS : | Yes |
Max Power Consumption : | 74.7W |
Operating Temperature : | 0-40°C (32°F - 104°F) |
MTBF (hours) : | 1,164,104 hours (132 years) |
FCC Class : | Class B |
Warranty | This product is backed by NETGEAR limited lifetime hardware warranty. |
| Click here for coverage, availability and terms and conditions. |
Support | NETGEAR Support offers a customizable support experience based on your operational needs: |
| Support coverage in one, three, or five year contracts |
